I have a feature class with just under 9.5 million rows that I want to load in R Studio. Here is my code:
arc.check_product()
point = arc.open(path = "...\\my.gdb\\my_feature_class")
point.df = arc.select(point)<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
However, it says it only loaded 3.6 million rows in my R Studio environment. I know that R Studio should be able to handle all of the rows because the following works fine:
dat <- data.frame(X=rep(0, 92500000))<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
I do have ~75 columns, so is there some other memory limitation I don't know about? Why would it not load my whole dataset? I have done this with several smaller datasets (~20k rows) without any issue.
