NOTE: I have updated this question from struggling to add a specific layer from a map service (as I have managed to work this out) to having a problem with adding raster layers (don't work) vs adding vector layers (which do work!).
I have a map service which has many layers of type "Raster Layer". It is stored on Portal. I can locate the exact layer I want (it's a single layer) - but when I add it to the map - the result never shows in the map. I just have an empty map.
However - if you change the code ever so slightly below to work against a Map Service with just vector/feature based layers - the layer loads ABSOLUTELY FINE!
So why is this not working for raster layers ?? This is beyond frustrating!!
Anyone have any ideas?
public static async void AddLayerToView()
Uri portalUri = new Uri("https://fooserver.foocompany.local/portal");
var portal = ArcGISPortalManager.Current.GetPortal(portalUri);
var owner = portal.GetSignOnUsername();
var portalInfo = await portal.GetPortalInfoAsync();
// Get all web maps and map services - include user, organization
// and "foo" in the title
var query2 = PortalQueryParameters.CreateForItemsOfTypes(new List<PortalItemType>() {
PortalItemType.WebMap, PortalItemType.MapService, PortalItemType.Layer}, owner, "", "Title:Foo");
query2.OrganizationId = portalInfo.OrganizationId;
//retrieve in batches of up to a 100 each time
query2.Limit = 100;
//Loop until done
var portalItems = new List<PortalItem>();
while (query2 != null)
//run the search
PortalQueryResultSet<PortalItem> results = await portal.SearchForContentAsync(query2);
portalItems.AddRange(results.Results);
query2 = results.NextQueryParameters;
RasterLayer rasterLayer = null;
//Layer vectorLayer = null; //UNCOMMENT FOR VECTOR
//process results
foreach (var pi in portalItems)
string itemID = pi.ID;
Item currentItem = ItemFactory.Instance.Create(itemID, ItemFactory.ItemType.PortalItem);
await QueuedTask.Run(() =>
var subItems = currentItem.GetItems();
foreach (var item in subItems)
if (item.Name == "MY_LAYER_NAME_TO_MATCH_ON")
if (LayerFactory.Instance.CanCreateLayerFrom(item))
rasterLayer = (RasterLayer)LayerFactory.Instance.CreateLayer(item, MapView.Active.Map);
//vectorLayer = LayerFactory.Instance.CreateLayer(item, MapView.Active.Map);//UNCOMMENT FOR VECTOR }
PS - Is there any way to make the above look more like code layout.
