Hi all,
I have encountered something interesting situation which might be the bug or I am wrong in implementing.
The situation is, I am using App Framework Network Request to get relevant data from the server-side. In order to do that, I found that 'DELETE' method is not accepted raw body as below.
networkRequest.url = some_url
networkRequest.method = "DELETE"
networkRequest.send(JSON.stringify({"keyA":"valueB"})
in the above case, there no body has sent.
But, it'll be in when I change its method as 'POST' as below.
networkRequest.method = "POST"
I also checked that it's working(but it's not raw body) when I set as form-data as below.
networkRequest.send({"keyA":"valueB"})
Have a check and let me know if you any.
Sean
