I upgraded to ArcGIS Pro 2.1.1 and all of a sudden i was getting this error whenever i tried to set an inspectors attribute
"This method or property must be called on the thread this object was created on"
I had never wrapped my inspector in queuedtask before this upgrade, but now am i required to with the upgrade from 2.0.8933 to 2.1.1? Will this affect my users running the 2.0.8933 version of ArcGIS Pro?
QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="punctuation token">{</SPAN>
inInspector<SPAN class="punctuation token">[</SPAN>fieldName<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> newValue<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
