I plan to customize the Draw widget that default from web AppBuilder, I plan to do is copy code from Clip and ship | ArcGIS API for JavaScript to the existing Draw widget, however, I didn't make it working.
How can I add the function in the "require" (from the HTML) into the "function" (stemapp\widgets\Draw\Widget.html), I tried to add them in the front, however, I kept getting the message "can not create widget" when re-starting the app. Has anyone have experiences?
I looked at the page from the tutorial: Create a custom in-panel widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers ,
Is there a better way to show my change for the application? currently I am doing is first remove the draw widget from the edit and then add a new one, however, it is kind of slow.
Look forward to hearing from you.
Peter
