I am working in a State Plane/NAD83 projection. I am adding a WMTS service that is is WGS 1984 on someone else's set. When the transformation window came up, I chose WGS 1984 to NAS 1983 V. But now I am realizing that I should have said none and let it project on the fly. So I close ArcMap, remove the connection file from the ArcCatalog (C:\Users\lperdue\AppData\Roaming\ESRI\Desktop10.2\ArcCatalog) folder. Then I copy the original connection file back to the clients set. When I add the WMTS service to the mxd again and specify NONE on
