I drew a graphic on a graphic layer (sample)
When running this through applyEdits on a featureLayer i get a success in return, but the geometry in the database becomes null or invalid.
If I draw a simple square or a circle, I don't see the same problem.
I also tried to take the same geometry into arcmap using json to features, the geometry appears correctly.
I have attached a sample JSON which does not work through applyEdits (even though it returns success and attributes are saved)
However, the shape looks perfectly well when importing using json to features.
