I am new to Appstudio and Qt. I succeeded in building the Map Viewer (4.1) app with a private web map.
Map Viewer (4.1) is a big (and for me complex) app. With my limited knowledge I am not able to downscale to a 'as simple as possible" app to display a private web map.
Whenever I try to load the web map in a simple example application like "Web Map" from the arcgis-appstudio-samples-4.0 Git, a grey screen appears, no error messages.
What should I add to be able to show the web map, just as in Map Viewer (4.1)
Company name and item id are changed in this listing
The code:
import QtQuick 2.7
import QtQuick.Controls 2.1
import QtQuick.Controls.Styles 1.4
import QtGraphicalEffects 1.0
import QtQuick.Controls.Material 2.1
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import Esri.ArcGISRuntime 100.2
Item { property real scaleFactor: AppFramework.displayScaleFactor
MapView { id:mapView
anchors.fill: parent
BusyIndicator { anchors.centerIn: parent
height: 48 * scaleFactor
width: height
running: true
Material.accent:"#8f499c"
visible: (mapView.drawStatus === Enums.DrawStatusInProgress)
Rectangle { anchors.fill: parent
color: "transparent"
ComboBox { id:combobox
anchors.left: parent.left
anchors.top: parent.top
anchors.margins: 10 * scaleFactor
width: 200 * scaleFactor
height: 30 * scaleFactor
clip:true
background: Rectangle { anchors.fill: parent
radius: 6 * scaleFactor
border.color: "darkgrey"
textRole:"name"
model: ListModel { id: cbItems
ListElement { name: "MYCOMPANY"; item: "XXXXXXXXXXXXXXXXXXXXXX" } ListElement { name: "San Francisco"; item: "358e6f9bebf544699b005f066886579c" } ListElement { name: "OpenstreetMap"; item: "0d22c9bc992f4f218605d6edb042ff89" } }
onCurrentIndexChanged: { loadWebMap(cbItems.get(currentIndex).item)
Component.onCompleted: { loadWebMap(cbItems.get(currentIndex).item)
function loadWebMap(webmapitemid){ var organizationPortalUrl = "https://mycompany-def.maps.arcgis.com/";
var webmapUrl = organizationPortalUrl + webmapitemid;
var newMap = ArcGISRuntimeEnvironment.createObject("Map", {initUrl: webmapUrl, autoFetchLegendInfos:true}); mapView.map = newMap;
