I have tables that have multiple geometries (extent, centroid, boundary,... ) so they have multiple registered views on top of them. If I need to make changes to the fields, how should I do this?
For example, I need to change the size of a text field from 32 to 60. In SQL, I would just make the change and go about my way.... In arcpy, I would:
- Rename the Field
- Add the field back with the new length
- Transfer the data
- Remove the renamed field
I'm not able to do this on the views, so I tried on the base table. Arcpy ran through and succeeded, but when I look at the COLUMN_REGISTERY table, the COLUMN_SIZE is still 32. I guess I expected with all of ArcMap's overhead, that it would figure out that it needed to update these values, but I guess it doesn't store the link from view to table, so how could it....I'm really tempted to just update those values.
I'm kind of assuming here that anytime I make a change to the base table or need to add/remove a field, I will have to:
- Unregister the View
- Make the change on the table
- [OPTIONAL] Make any changes on the view if necessary
- Re-register the view
