Configuring Portal in the ArcGIS Enterprise failover mode will affect the ArcGIS server in HA mode .in this scenario the portal is active node and the second joind machine is passive. I configured the NLB to send 100 % request to the first portal then the portal will communicate with one of the ArcGIS server what if the active node faild while it is passing the request from the ArcGIS server will the passive node swich on and still hold the requested result.
this is still under testing from my side any advice., is this supported .JQuinn-esristaff
thanks
ramla
