When I run the dependent_to() method on an item, it returns a dict with a list of 10 items, but I know that there are more than 10 items that depend on this layer in our ArcGIS Portal.
There is nothing in the API documentation that indicates what the maximum return is, and I only ask because I know the Content Manager Search function limits to 10 unless you pass the maxCount argument.
This is an example of the dict I receive when I run the dependent_to() method.
<SPAN class="punctuation token">{</SPAN><SPAN class="string token">'list'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">'dependencyType'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'7d793691da654aebbb621591fe37c362'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN><SPAN class="string token">'dependencyType'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'3e344caf8d514efcb840ef55577805ab'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN><SPAN class="string token">'dependencyType'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'3580e445750e44d7b964ccb7866940b2'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN><SPAN class="string token">'dependencyType'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'860a10f4b36b4d3f96319c086483a1f1'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN><SPAN class="string token">'dependencyType'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'d931b4a4701541f4ae97e39538e02b99'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN><SPAN class="string token">'dependencyType'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'d5966d50898646a891bab7392d7b1a25'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN><SPAN class="string token">'dependencyType'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'39e5d85e914f42ef9c0968581b94ec98'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN><SPAN class="string token">'dependencyType'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'57706f042b014a728bc66b91226259be'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN><SPAN class="string token">'dependencyType'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'c00ac7e5547d4ae7ac29162d3003813b'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN><SPAN class="string token">'dependencyType'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'id'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'b93efd97b2234c51988412a440a6e68a'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'start'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'total'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'nextStart'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'fullCount'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Hopefully I am missing something simple?
