Have several sde geodatabases stored in SQL Server Express instance.
Just created new Linux Ubuntu instance of PostgreSQL, added st_geometry.so file to /lib.
I used the create enterprise geodatabase tool in ArcMap; sucessfully created sde gdb on PostgreSQL server.
To migrate the data:
1) export XML workspace file from SQL server sde gdb
2) attempt to import the XML workspace file to the PostgreSQL sde gdb
Error:
"database user name and current user schema do not match".
Can someone explain how to migrate the data to new PostgreSQL instance?
thanks.
