Is there a way to reset an ArcGIS Web Mapping Application back to default settings for everything (i.e. widgets, settings, etc)?
One of my web mapping applications is acting abnormally, which seems to have started after the most recent ArcGIS Online update. My other web mapping applications with similar functionality are working normally though. I have a couple view tables in this particular web app and the attribute table widget will not open for those (the spinning timer will circle for hours); however, attribute tables will open for all my other layers in this web app. Also, when I go to the web map associated with this web app, the view tables work perfectly in the web map. The issue seems to be in the web mapping application. I just want to reset it and start with fresh settings, but I cannot delete it and start over (need the url to stay the same).
