Hi there!
I have an issue with exporting the annotation of polyline features to dwg.
Basically the export works, but the problem is, that the annotation does have carriage returns and so the annotation in the dwg-file now is MTEXT and not (as usual) TEXT. In the attribute table of the annotation the alignment is "bottom center" which would be fine, but after the export to CAD the alignment is "upper left" which relocates the label.
Its not possible to just edit this in AutoCAD to "bottom center" (as it should be) because in this case only the insert point moves.
