I am writing an application in asp.net in visual studio 2013 using c#, javascript and css. I am using esri javascript api and esri dijit themes.
The claro.css theme is not being read by the application. It is the only css with this problem. When I check in the web debugger inspector, the theme is not listed for the div anywhere in the inspect list. The two other esri dijits (popup.css and esri.css) are being read. My custom theme viewer.css is being read. I did have to put in an override for my viewer.css theme or else the esri.css kept reading over it. Without using override claro my custom css page will not be overridden by the esri.css . If I remove the override claro, the
