Hello, I am trying to change update a SOE via Python script. I am using /arcgis/admin/uploads/upload POST request, but I am getting an error.
<SPAN class="comment token"># minimal example of changing an SOE</SPAN>
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> os<SPAN class="punctuation token">,</SPAN> httplib<SPAN class="punctuation token">,</SPAN> json<SPAN class="punctuation token">,</SPAN> socket<SPAN class="punctuation token">,</SPAN> sys<SPAN class="punctuation token">,</SPAN> urllib<SPAN class="punctuation token">,</SPAN> requests
username <SPAN class="operator token">=</SPAN> <SPAN class="string token">'admin'</SPAN>
password <SPAN class="operator token">=</SPAN> <SPAN class="string token">'enter_password_here'</SPAN>
<SPAN class="comment token"># get IPV4 address</SPAN>
hostname <SPAN class="operator token">=</SPAN> socket<SPAN class="punctuation token">.</SPAN>gethostname<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
serverName <SPAN class="operator token">=</SPAN> socket<SPAN class="punctuation token">.</SPAN>gethostbyname<SPAN class="punctuation token">(</SPAN>hostname<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># IPV4 Address</SPAN>
serverPort <SPAN class="operator token">=</SPAN> <SPAN class="number token">6080</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">getToken</SPAN><SPAN class="punctuation token">(</SPAN>username<SPAN class="punctuation token">,</SPAN> password<SPAN class="punctuation token">,</SPAN> serverName<SPAN class="punctuation token">,</SPAN> serverPort<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
tokenURL <SPAN class="operator token">=</SPAN> <SPAN class="string token">"/arcgis/admin/generateToken"</SPAN>
params <SPAN class="operator token">=</SPAN> urllib<SPAN class="punctuation token">.</SPAN>urlencode<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">'username'</SPAN><SPAN class="punctuation token">:</SPAN> username<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'password'</SPAN><SPAN class="punctuation token">:</SPAN> password<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'client'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'requestip'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'f'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'json'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
headers <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">"Content-type"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"application/x-www-form-urlencoded"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Accept"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"text/plain"</SPAN><SPAN class="punctuation token">}</SPAN>
<SPAN class="comment token"># Connect to URL and post parameters</SPAN>
httpConn <SPAN class="operator token">=</SPAN> httplib<SPAN class="punctuation token">.</SPAN>HTTPConnection<SPAN class="punctuation token">(</SPAN>serverName<SPAN class="punctuation token">,</SPAN> serverPort<SPAN class="punctuation token">)</SPAN>
httpConn<SPAN class="punctuation token">.</SPAN>request<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"POST"</SPAN><SPAN class="punctuation token">,</SPAN> tokenURL<SPAN class="punctuation token">,</SPAN> params<SPAN class="punctuation token">,</SPAN> headers<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Read response</SPAN>
response <SPAN class="operator token">=</SPAN> httpConn<SPAN class="punctuation token">.</SPAN>getresponse<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">.</SPAN>status <SPAN class="operator token">!=</SPAN> <SPAN class="number token">200</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
httpConn<SPAN class="punctuation token">.</SPAN>close<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Error while fetching tokens from admin URL. Please check the URL and try again."</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
data <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
obj <SPAN class="operator token">=</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>data<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="string token">'status'</SPAN> <SPAN class="keyword token">in</SPAN> obj <SPAN class="operator token">and</SPAN> obj<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'status'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="string token">"error"</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># Extract the token from it</SPAN>
<SPAN class="keyword token">return</SPAN> obj<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'token'</SPAN><SPAN class="punctuation token">]</SPAN>
token <SPAN class="operator token">=</SPAN> getToken<SPAN class="punctuation token">(</SPAN>username<SPAN class="punctuation token">,</SPAN> password<SPAN class="punctuation token">,</SPAN> serverName<SPAN class="punctuation token">,</SPAN> serverPort<SPAN class="punctuation token">)</SPAN>
soe_path <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"C:\Users\test-user\Documents\SOI_Test1.soe"</SPAN>
<SPAN class="comment token"># upload the soe file</SPAN>
upload_url <SPAN class="operator token">=</SPAN> <SPAN class="string token">"https://localhost:6443/arcgis/admin/uploads/upload?f=json"</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>token<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">import</SPAN> requests
<SPAN class="keyword token">with</SPAN> open<SPAN class="punctuation token">(</SPAN>soe_path<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'rb'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> f<SPAN class="punctuation token">:</SPAN>
data <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"token"</SPAN><SPAN class="punctuation token">:</SPAN> token
response <SPAN class="operator token">=</SPAN> requests<SPAN class="punctuation token">.</SPAN>post<SPAN class="punctuation token">(</SPAN>upload_url<SPAN class="punctuation token">,</SPAN> data<SPAN class="punctuation token">,</SPAN> files<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">'itemFile'</SPAN><SPAN class="punctuation token">:</SPAN> f<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I am just getting a token and using it to try to call /arcgis/admin/uploads/upload. The post request gives error:
File "C:\Users\test-user\Documents\change_soe.py", line 53, in <module>
response = requests.post(upload_url, data, files={'itemFile': f})
File "C:\Python27\ArcGIS10.7\lib\site-packages\requests\api.py", line 110, in post
return request('post', url, data=data, json=json, **kwargs)
File "C:\Python27\ArcGIS10.7\lib\site-packages\requests\api.py", line 56, in request
return session.request(method=method, url=url, **kwargs)
File "C:\Python27\ArcGIS10.7\lib\site-packages\requests\sessions.py", line 475, in request
resp = self.send(prep, **send_kwargs)
File "C:\Python27\ArcGIS10.7\lib\site-packages\requests\sessions.py", line 596, in send
r = adapter.send(request, **kwargs)
File "C:\Python27\ArcGIS10.7\lib\site-packages\requests\adapters.py", line 497, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The token works with /arcgis/admin/services/FOLDER/SERVICE_NAME.MapServer/edit, but I used httplib.HTTPConnection request method. I am not sure why it is not working with requests library here.
