I have a network of triangles (TIN) and when I draw them all on a feature layer I can easily merge them together into one big polygon (or a few polygons) with EditOperation.Merge. Works well and so far so good.
But of course it's a bit silly to draw for example 100000 triangles (which takes ages) and THEN merge them. Instead it would be much better to have the PolygonBuilder create the polygons and then merge them right away and just add one big polygon onto my feature layer. In pseudocode it would look a bit like this:
<SPAN class="keyword token">var</SPAN> editOp <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> polygons <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">List</SPAN><SPAN class="operator token"><</SPAN>Polygon<SPAN class="operator token">></SPAN><SPAN class="punctuation token">(</SPAN>myTriangles<SPAN class="punctuation token">.</SPAN>Count<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">foreach</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> tr <SPAN class="keyword token">in</SPAN> myTriangles<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> coordinates <SPAN class="operator token">=</SPAN> tr<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetCoordinates3D</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> pg <SPAN class="operator token">=</SPAN> PolygonBuilder<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreatePolygon</SPAN><SPAN class="punctuation token">(</SPAN>coordinates<SPAN class="punctuation token">,</SPAN> spatialRef<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
polygons<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN>pg<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
editOp<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Merge</SPAN><SPAN class="punctuation token">(</SPAN>polygons<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">await</SPAN> editOp<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ExecuteAsync</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I know this doesn't work right ouf of the box but is there a way I can do this? After all, the merge functionality is there and I don't see why EditOperation.Merge shouldn't work on a sequence of polygons just as it does work on a sequence of Object IDs...
Thanks in advance
Christian
