I need to programmatically clone a layout element many times but it keeps crashing ArcGIS Pro. I have narrowed it down to this snippet:
GraphicElement element = layout.FindElement(DefaultSymbols.DEFAULT_SYMBOL_NAME) as GraphicElement;
for (int i=0; i<1000; i++)
GraphicElement clonedElement = element.Clone();
clonedElement.SetName(elementName + i);
This code never completes. It gets a couple of hundred in and then excepts (the number of times through the loop varies from run to run). I am running this code inside of a QueuedTask.Run(). If I remove the SetName() I can get through more iterations (usually more than 1,000), but it still fails. Below are the stack traces it produces. Any suggestions about how to avoid this issue?
Trace with SetName()
System.Transactions Critical: 0 : <TraceRecord xmlns="http://schemas.microsoft.com/2004/10/E2ETraceEvent/TraceRecord" Severity="Critical"><TraceIdentifier>http://msdn.microsoft.com/TraceCodes/System/ActivityTracing/2004/07/Reliability/Exception/Unhandled</TraceIdentifier><Description>Unhandled exception</Description><AppDomain>ArcGISPro.exe</AppDomain><Exception><ExceptionType>System.NullReferenceException, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</ExceptionType><Message>Object reference not set to an instance of an object.</Message><StackTrace> at ArcGIS.Desktop.Layouts.Element.IsFrameElement(Element element)
at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable`1 source, Func`2 predicate)
at ArcGIS.Desktop.Layouts.Element.SelectionHasFrame()
at ArcGIS.Desktop.Layouts.Element.GetSelectedSubElements()
at ArcGIS.Desktop.Layouts.Layout.&lt;&gt;c__DisplayClass130_0.&lt;UpdateGUISelectionAsync&gt;b__0()
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean&amp; handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean&amp; handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG&amp; msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at main(String[] args)</StackTrace><ExceptionString>System.NullReferenceException: Object reference not set to an instance of an object.
at main(String[] args)</ExceptionString><DataItems><Data></Data></DataItems></Exception></TraceRecord>
An unhandled exception of type 'System.NullReferenceException' occurred in ArcGIS.Desktop.Layouts.dll
Trace without SetName()
System.Transactions Critical: 0 : <TraceRecord xmlns="http://schemas.microsoft.com/2004/10/E2ETraceEvent/TraceRecord" Severity="Critical"><TraceIdentifier>http://msdn.microsoft.com/TraceCodes/System/ActivityTracing/2004/07/Reliability/Exception/Unhandled</TraceIdentifier><Description>Unhandled exception</Description><AppDomain>ArcGISPro.exe</AppDomain><Exception><ExceptionType>System.ArgumentException, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</ExceptionType><Message>Destination array was not long enough. Check destIndex and length, and the array's lower bounds.</Message><StackTrace> at System.Array.Copy(Array sourceArray, Int32 sourceIndex, Array destinationArray, Int32 destinationIndex, Int32 length, Boolean reliable)
at System.Collections.Generic.List`1.CopyTo(T[] array, Int32 arrayIndex)
at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
at ArcGIS.Desktop.Internal.Layouts.ElementContainer.ArcGIS.Desktop.Internal.Layouts.IElementContainerInternal.GetFlattenedElements()
at ArcGIS.Desktop.Internal.Layouts.ElementContainer.ArcGIS.Desktop.Internal.Layouts.IElementContainerInternal.FindElement(String elementName, Boolean recurse)
at ArcGIS.Desktop.Internal.Layouts.Utilities.ElementUtil.&lt;&gt;c__DisplayClass5_0.&lt;SelectedElements&gt;b__0(String name)
at System.Linq.Enumerable.WhereSelectArrayIterator`2.MoveNext()
at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source)
at ArcGIS.Desktop.Internal.Layouts.Utilities.ElementUtil.SelectedElements()
at main(String[] args)</StackTrace><ExceptionString>System.ArgumentException: Destination array was not long enough. Check destIndex and length, and the array's lower bounds.
An unhandled exception of type 'System.ArgumentException' occurred in mscorlib.dll
