Hei,
I have Data Interoperability ETL Spatial Tool which is reading multiple gml-files from a directory processing them together (merge, dissolve, remove duplicates etc) and writing features to the SDE Geodatabase. Need to use truncate for table before writing.
In DI I have Reader Source like: D.\temp\input\*.gml.
When running this as DI Spatial ETL Tool it works fine. It read all the files => process them together =write to SDE.
Now I need to make ArcGIS Service from this DI tool. It needs Model. I can place DI ETL Spatial Tool to Model without problems. But how to make model process all source gml-files together? I have tested everything without success. Trying to place Folder-parameter and File-Iteration or List of files. But Model always execute one gml-file at a time before reading next one and the result is output table containing features only from the last file.
Help needed. I am not so familiar with ModelBuilder- All hints and tips are welcome.
With FME and FME Server this is so easy. Data Interoperability drives me crazy.
