I created a geodatabase via ArcGIS Runtime Content in ArcMap.
I am trying to add it via this reference: Create an offline map—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
BUT map.addLayer does not exist or its giving me an error
Any ideas?
<SPAN class="comment token">//Declare the geodatabase </SPAN>
Geodatabase <SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> geodatabase
path<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"/path_to_my_geodatabase/mydata.geodatabase"</SPAN>
<SPAN class="punctuation token">}</SPAN>
FeatureLayer <SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> featureLayer
featureTable<SPAN class="punctuation token">:</SPAN> geodatabase<SPAN class="punctuation token">.</SPAN><SPAN class="token function">geodatabaseFeatureTableByLayerId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
