I'm having trouble with oflline workflows for Collector for couple of days now.
I work in north east Nigeria and therefore need to download maps ahead of time for field workers marking potential mine fields. I've created an AGOL webmap and then create the Map Areas. However, when I open Collector I see the webmap with the editable layer but not the predefined Map Areas. I'm able to access the webmap, the download option is available but the I don't see the Map Areas anywhere in the application.
I'm not always in the office where the the fieldworkers are located. Therefore, I require a method to remotely create and share Map Areas which the field workers will use to conduct marking surveys.
Any thoughts, suggestions, or solutions would be welcome.
