I am trying to create a customized timeslider widget to visualize temporal data.
I was able to show the data on the map and the data changes by the timeslider.
However, the tick does not move when I use setTimeout() to show animated visualization.
The data includes fields which indicate temporal, so I filter features using layer.definitionExpression.
Timeslider is created by using input element. When I move the tick in the element, change event fires and features are filtered.
I also add animation by using setTimeout. I was able to show animation, but when I use animation, the tick deos not move. And this is the issue I am facing to.
I attached source code (I deleted some codes, which refer the service I use).
I am new to TypeScript and widget development.
So I could miss something basic, but it would be greate if I can get any infromation about the issue.
