When syncing an offline map (with a pre-packaged map area) edits that are made from collector go to the web map but are not updated onto the offline map. Essentially, what I am doing is updating view layers that when a field value is changed will alter the visibility of a another feature. So when i sync, the updates go to the web map and edits the layers correctly but the changes are not sent back to the offline map even after another sync.
