I'm setting the map extent to a dynamic layer once it's loaded using the following code. layerDynamic.on("load", function () { var deferred = new Deferred(); deferred = map.setExtent(layerDynamic.initialExtent, true); deferred.then(function () { console.log("map xmin: " + map.extent.xmin + ", ymin: " + map.extent.ymin + ", xmax: " + map.extent.xmax + ", ymax: " + map.extent.ymax) console.log("layer xmin: " + layerDynamic.initialExtent.xmin + ", ymin: " + layerDynamic.initialExtent.ymin + ", xmax: " + layerDynamic.initialExtent.xmax + ", ymax: " + layerDynamic.initialExtent.ymax) }); });However, this doesn't always work. When I refresh the page, it often zooms out way too far. This is what the extents usually are when it doesn't zoom correctlymap xmin: -27374674.768619433, ymin: -2290122.0955929635, xmax: -6828401.565569537, ymax: 6241473.253482993 layer xmin: -14166895.9892999, ymin: 5762234.783315, xmax: -13598348.0746001, ymax: 6211946.863385
Why doesn't that code work upon a refresh?
