ESRI Object in ResourceDictionary throwing errors
I created an ESRI PictureMarkerSymbol resource (shown below) in the Resource Dictionary file that my application uses. Whenever that or any ESRI resource is in that Resource Dictionary my MainPage.xaml cannot be viewed in design mode. I get a nasty error page in its place, which contains 3 different exceptions. The minute I take the ESRI stuff out of my Resource Dictionary and rebuild the app, everything is fine back in the MainPage.xaml. Has anyone had similar problems or know of a workaround to this issue? Thanks in advance for any help you can provide ...
Andy
Here is the resource XAML ...
<esri:PictureMarkerSymbol x:Key="AddressSearchMarkerSymbol" Source="/SRPMO;component/Images/Tools/address_search.png" Height="30" Width="30">
<esri:PictureMarkerSymbol.ControlTemplate>
<ControlTemplate>
<Canvas>
<VisualStateManager.VisualStateGroups>
<VisualStateGroup x:Name="CommonStates">
<VisualState x:Name="MouseOver">
<Storyboard RepeatBehavior="ForEver">
<DoubleAnimation BeginTime="0" Storyboard.TargetName="ellipse" Storyboard.TargetProperty="(UIElement.RenderTransform).(ScaleTransform.ScaleX)" From="1" To="10" Duration="00:00:01" />
<DoubleAnimation BeginTime="0" Storyboard.TargetName="ellipse" Storyboard.TargetProperty="(UIElement.RenderTransform).(ScaleTransform.ScaleY)" From="1" To="10" Duration="00:00:01" />
<DoubleAnimation BeginTime="0" Storyboard.TargetName="ellipse" Storyboard.TargetProperty="(UIElement.Opacity)" From="1" To="0" Duration="00:00:01" />
</Storyboard>
</VisualState>
<VisualState x:Name="Normal" />
</VisualStateGroup>
</VisualStateManager.VisualStateGroups>
<Ellipse Height="10" Width="10" Canvas.Left="-5" Canvas.Top="-5" RenderTransformOrigin="0.5,0.5" x:Name="ellipse" IsHitTestVisible="False">
<Ellipse.RenderTransform>
<ScaleTransform />
</Ellipse.RenderTransform>
<Ellipse.Fill>
<RadialGradientBrush>
<GradientStop Color="#00FF0000" />
<GradientStop Color="#FFFF0000" Offset="0.25"/>
<GradientStop Color="#00FF0000" Offset="0.5"/>
<GradientStop Color="#FFFF0000" Offset="0.75"/>
<GradientStop Color="#00FF0000" Offset="1"/>
</RadialGradientBrush>
</Ellipse.Fill>
</Ellipse>
<Image x:Name="image" Source="/SRPMO;component/Images/Tools/address_search.png" Height="30" Width="30" HorizontalAlignment="Center" VerticalAlignment="Center" Canvas.Left="-15" Canvas.Top="-15" />
</Canvas>
</ControlTemplate>
</esri:PictureMarkerSymbol.ControlTemplate>
</esri:PictureMarkerSymbol>
Here are the errors I am getting ...
ERROR 1:
System.Reflection.TargetInvocationException
Exception has been thrown by the target of an invocation.
at System.RuntimeMethodHandle._InvokeMethodFast(IRuntimeMethodInfo method, Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeType typeOwner)
at System.RuntimeMethodHandle.InvokeMethodFast(IRuntimeMethodInfo method, Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeType typeOwner)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
at System.Delegate.DynamicInvokeImpl(Object[] args)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
ERROR 2:
System.InvalidOperationException
An unhandled exception was encountered while trying to render the current silverlight project on the design surface. To diagnose this failure, please try to run the project in a regular browser using the silverlight developer runtime.
at Microsoft.Windows.Design.Platform.SilverlightViewProducer.OnUnhandledException(Object sender, ViewUnhandledExceptionEventArgs e)
at Microsoft.Windows.Design.Platform.SilverlightViewProducer.SilverlightContentHost.MeasureOverride(Size availableSize)
at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
at System.Windows.UIElement.Measure(Size availableSize)
at MS.Internal.Designer.ZoomableViewPresenter.DesignerBackground.MeasureOverride(Size constraint)
at System.Windows.Controls.Decorator.MeasureOverride(Size constraint)
at Microsoft.Windows.Design.Interaction.DesignerView.MeasureOverride(Size constraint)
at MS.Internal.Designer.Viewport.MeasureOverride(Size availableSize)
at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
at System.Windows.Controls.ScrollContentPresenter.MeasureOverride(Size constraint)
at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV)
at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
at System.Windows.Controls.ScrollViewer.MeasureOverride(Size constraint)
at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
at System.Windows.Controls.Control.MeasureOverride(Size constraint)
at System.Windows.Interop.HwndSource.SetLayoutSize()
at System.Windows.Interop.HwndSource.set_RootVisualInternal(Visual value)
at System.Windows.Interop.HwndSource.set_RootVisual(Visual value)
at MS.Internal.DeferredHwndSource.ProcessQueue(Object sender, EventArgs e)
ERROR 3:
System.Exception
Error HRESULT E_FAIL has been returned from a call to a COM component.
at MS.Internal.XcpImports.CheckHResult(UInt32 hr)
at MS.Internal.XcpImports.FrameworkElement_MeasureOverride(FrameworkElement element, Size availableSize)
at System.Windows.FrameworkElement.MeasureOverride(Size availableSize)
at System.Windows.FrameworkElement.MeasureOverride(IntPtr nativeTarget, Single inWidth, Single inHeight, Single& outWidth, Single& outHeight)
