I want to add a legend, it works when I add several layers together. But when I want to add just a single layer, I make the code as the following: var legendLayer = []; map.on("layer-add-result", function (evt) { legendLayer.push({ layer: Layer1, title: 'AAABBC' }); var legendDijit = new Legend({ map: map, layerInfos: legendLayer }, "legendDiv"); legendDijit.startup(); }); map.addLayer(Layer1);Everytime I change a basemap or scroll the mouse wheel, it adds the extra same legend to the legend pane. When I add multi-layers, using the following code it always works, I just change the "layers-add-result" to "layer-add-result", then it does not work. So what should I do if just want to add a single layer? Thanks a lot!map.on("layers-add-result", function (evt) { var layerInfo = arrayUtils.map(evt.layers, function (layer, index) { return { layer: layer.layer, title: layer.layer.name }; }); if (layerInfo.length > 0) { var legendDijit = new Legend({ map: map, layerInfos: layerInfo }, "legendDiv"); legendDijit.startup(); } }); map.addLayers([Layer1, Layer2]);
