Hello, I know that this theme was discussed few times, but I didnt solve the problem using informations that I've found here.There is (for many of you well known) problem with coding. <type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\xa0' in position 11: ordinal not in range(128)I enter ID number (data type string) but the script ends with error. I have tried .encode('utf-8'), .replace(u'\xa0', ' ') but it was no solution.First - problematic - part of the script is below:import arcpy, sys, os, shutil
from arcpy import env
obecJmeno = arcpy.GetParameter(0)
adr_puvodni = u"C:\\vydej2\\mapy_!empty_2013"
adr_nove="C:\\vydej2\\Data_Export\\mapy_"+obecJmeno+"_2013"
vyberZ=arcpy.GetParameter(1)
ID=arcpy.GetParameter(2)
if vyberZ=="obec":
vyber= "C:\\vydej2\\Data\\CZ020STCE11obc_poly.shp"
sqlstat= "\"KOD_OBC_TX\"=" + "'" + ID+ "'"
elif vyberZ=="opu":
vyber= "C:\\vydej2\\Data\\CZ020STCE11opu_poly.shp"
sqlstat= "\"KOD_OPU_TX\"=" + "'" + ID+ "'"
etc
Any ideas please?Btw - this script was fully working yesterday on my collegues computer. Today it doesnt work at his PC as well as at mine. ArcGIS 10.0 build 4400
