I have this script that run fine until it hits the final part FocalStatistics. Any ideas as to why it is failing? Below is the script and below the script is the error i get when i run the script.
# Name:
# Purpose:
# Author: Shawn Keizer
# Created: 06/10/2015
# Copyright: (c) Government of Alberta
def focalStats(inRaster, neighbourHood, outRaster):
"""Calculates for each input cell location a statistic of the values within a specified neighborhood around it."""
outraster = FocalStatistics(inRaster, neighbourHood, "MEAN", "DATA")
outraster.save(outRaster)
def main():
AOI = r"C:\_LOCALdata\Projects\Barred_Owl\ConvertModelToScript\AOI.shp" # the area of interest to find the rasters for
rFolder = "//env.gov.ab.ca/GIS/GISdata/ttm/data/base/topo/25mDEM" # the folder containing the rasters to search from
oFolder = r"C:\_LOCALdata\Projects\Barred_Owl\ConvertModelToScript" # the folder to copy to
desc = arcpy.Describe(AOI) # get the extent of the AOI
sExt = desc.extent
arcpy.env.workspace = rFolder
env.overwriteOutput = True
try:
arcpy.AddField_management(AOI,"UTM_Zone","TEXT","","", 255)
except:
print "UTM_Zone field already exist..."
myLyr = arcpy.MakeFeatureLayer_management(AOI, "AOI_Layer")
arcpy.CalculateUTMZone_cartography("AOI_Layer", "UTM_Zone")
for row in arcpy.da.SearchCursor("AOI_Layer", ["UTM_Zone"]):
myStr = str(row)
if "North American 1983 UTM Zone 11U" in myStr:
zone = "NAD_1983_UTM_Zone_11N"
else:
zone = "NAD_1983_UTM_Zone_12N"
del myLyr
myRasLst = []
for ThisRas in arcpy.ListRasters():
rDesc = arcpy.Describe(ThisRas)
rExt = rDesc.extent
sr = rDesc.spatialReference
if sr.name == zone:
if sExt.disjoint(rExt):
pass
else:
arcpy.AddMessage("Raster %s overlaps " % (ThisRas) + sr.name)
print "Raster %s overlaps " % (ThisRas) + sr.name
outFile = os.path.join(oFolder,ThisRas)
arcpy.Copy_management(os.path.join(rFolder,ThisRas),outFile)
myRasLst.append(os.path.join(oFolder,ThisRas))
if len(myRasLst) > 1:
for rs in myRasLst:
if rs != myRasLst[0]:
arcpy.Mosaic_management(rs,myRasLst[0],"MEAN")
focalStats(myRasLst[0], NbrRectangle(100, 100, "CELL"), os.path.join(oFolder,"mElev100Ha"))
if __name__ == '__main__':
import os, sys, arcpy
from arcpy import env
from arcpy.sa import *
main()Traceback (most recent call last):
File "<string>", line 254, in run_nodebug
File "C:\_LOCALdata\Projects\Barred_Owl\ConvertModelToScript\Test.py", line 67, in <module>
main()
File "C:\_LOCALdata\Projects\Barred_Owl\ConvertModelToScript\Test.py", line 61, in main
File "C:\_LOCALdata\Projects\Barred_Owl\ConvertModelToScript\Test.py", line 14, in focalStats
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\sa\Functions.py", line 4830, in FocalStatistics
ignore_nodata)
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\sa\Utils.py", line 47, in swapper
result = wrapper(*args, **kwargs)
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\sa\Functions.py", line 4824, in wrapper
ignore_nodata)
File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\geoprocessing\_base.py", line 498, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 999999: Error executing function.
Failed to create raster dataset
Failed to execute (FocalStatistics).
Message was edited by: Dan Patterson I took the liberty of formatting the code using Syntax highlighting in the >>> menu options, selecting Python
