Hello, I'm trying to push some xml over udp to GeoEvent. I am able to get most of the xml coming through. However I'm having issue with a particular tags - GPS & Details.
Now I know they don't have full closing tags. would this be an issue? Equally the tags will not always be populated (like details).
Is there anyway to work with this xml?
The xml sample is here
<SPAN class="prolog token"><?xml version="1.0" encoding="utf-8"?></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Location</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>xsd</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://www.w3.org/2001/XMLSchema<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>xsi</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://www.w3.org/2001/XMLSchema-instance<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">ReportDateTime</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>2012-03-22T14:37:46Z<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">xmlns</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://tempuri.org/XMLSchema.xsd<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>IamNameBoat<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>GPS</SPAN> <SPAN class="attr-name token">Latitude</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>35.6605573<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Longitude</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>-40.8234387<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Speed</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Speed</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Accuracy</SPAN><SPAN class="punctuation token">></SPAN></SPAN>187<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Accuracy</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Details</SPAN><SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Location</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
