Problems Creating Projection File
I was given some CAD Data and told it was in a 10TM projection, included in the meta data was the following information:
GEOGRAPHIC LOCATION: Latitude: 49:0:0
Longitude: 110:0:0
PROJECTION: 10 DEGREE TRANSVERSE MERCATOR
PROJECTION ID: 0202
CENTRAL MERIDIAN: 115
COMBINED SCALE FACTOR: 0
IGDS GLOBAL ORIGIN: X = 500000 Y = -5000000
DESIGN SCALE: 1000000
DATUM: NAD83
COMMENTS: 1:1,000,000 POSITION FILE
This is my attempt at the projection file:
PROJCS["10TM",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",-5000000.0],PARAMETER["Central_Meridian",115.0],PARAMETER["Scale_Factor",0.0],PARAMETER["Latitude_Of_Origin",49.0],UNIT["Meter",1.0]]
If someone could explain where I am going wrong that would be fantastic, keep in mind I am a relatively novice user,
Thanks in advance
