I'm working on Map Series where I'm using dynamic text to access the current layer information from the data base which working fine, but the issue which I'm facing now is I have one layer where I applied "definition query " from its properties. But in my map series that definition query is applicable to that particular area only, I want it should be applied to all my map series and it should work in loop.
Image you can see I have one column which shows the values in it.
in other image, I applied one definition query on the layer which is working fine for only one page where that condition is satisfied, but on other pages it is not working as I required.
please help
Membros conectados podem postar, seguir atualizações e mais. Novo aqui? Registre uma conta gratuita.
