I have an IFeatureClass created in my code and I have added a new field to it. I'm stuck on calculating values for the new field. I've tried using CalculateField and ICalculator but I get errors from both (see code below). Any suggestions?
IFeatureClass classifiedPolygons_IFC
IFieldEdit2 field
* Error HRESULT E_FAIL has been returned from a call to a COM component.
* I've also tried casting the IFeatureClass to ITable
CalculateField calculateField = new CalculateField()
in_table = classifiedPolygons_IFC,
field = classifiedPolygons_IFC.Fields.Field[classifiedPolygons_IFC.Fields.FindField(field.Name)],
expression = "Calc Val",
expression_type = "Python"
Geoprocessor gp = new Geoprocessor();
gp.Execute(calculateField, null);
* "Retrieving the COM class factory for component with CLSID {D676066E-38CA-429A-B846-DA7A8446C52D} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))."
ICursor updateCursor = classifiedPolygons_IFC.Update(null, false) as ICursor;// table.Update(null, false);
ICalculator calculator = new Calculator()
Cursor = updateCursor,
Field = field.Name,
Expression = "Calc Val"
calculator.Calculate();
Marshal.FinalReleaseComObject(updateCursor);
