Hey there.
Im starting to develop a little app that it has to search a value in a feature layer and give the result in some html List and also make a zoom in a map with the current location (i would like to add the infotemplate from the feature).
Im programming with esri-angular api, but i dont find any example of :
1.- How to query data from a featurelayer
2.- How to make a zoom to the founded feature.
3.- Is there a way to not use this to add the feature layers and doing it through code?
<esri-feature-layer url="http://services.arcgis.com/rOo16HdIMeOBI4Mb/arcgis/rest/services/Heritage_Trees_Portland/FeatureServer/0"></esri-feature-layer>
<esri-feature-layer url="http://services.arcgis.com/rOo16HdIMeOBI4Mb/arcgis/rest/services/Portland_Parks/FeatureServer/0"></esri-feature-layer>
Thanks in advice for ur help guys as always
I just have this on my code:
Mapa.JS
angular.module('myApp', ['esri.map'])
.controller('MapController', function ($scope) {
$scope.map = {
center: {
lng: -71.51079005370974,
lat: -33.0324567956618},
zoom: 10
});Html File:
<div class="content-block contact-3 bg-clouds" id="busqueda" ng-controller="MapController">
<div class="container">
<div class="row">
<div class="underlined-title">
<h1>Buscar NIS de Cliente</h1>
<hr>
</div>
<div class="row">
<form role="form">
<div class="col-md-4">
<div class="form-group">
<label class="control-label" for="formInput13">Ingrese el NIS del cliente a buscar:</label>
<input type="text" class="form-control" id="formInput13" placeholder="NIS" required>
</div>
</div>
<button type="button" class="btn btn-default btnBuscar bg-moonlight offwhite" id="searchBtn">
<i class="fa fa-search"></i> Buscar
</button>
</div>
</form>
</div>
<div class="col-md-6">
<div id="contact" class="form-container">
<h2>Resultados de la búsqueda:</h2>
<fieldset>
<ul>
<li>Lat: {{map.center.lat}}</li>
<li>Address: {{map.layer.address}}</li>
<li>Pipe: {{map.layer.pipe}}</li>
<li>Status: {{map.layer.status}}</li>
<li>Nulla volutpat aliquam velit
<ul>
<li>Phasellus iaculis neque</li>
<li>Purus sodales ultricies</li>
</ul>
</li>
</ul>
</fieldset>
<p>
Lat:<input type="number" step="0.1" ng-model="map.center.lat" />
Lng:<input type="number" step="0.1" ng-model="map.center.lng" />,
Zoom: <select ng-model="map.zoom" ng-options="level for level in [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19]"></select>
</p>
</div>
<!-- /.form-container -->
</div>
<h2>Ubicación</h2>
<p>Lugar donde actualmente se encuentra el NIS.</p>
<div class="row pg-empty-placeholder containerMap"><esri-map id="map" center="map.center" zoom="map.zoom" basemap="topo"></esri-map>
</div></div>
</div>
</div>
<!-- /.row -->
</div>
<!-- /.container -->
</div>
