Hi Gents,
I am using Arcmap 10.5.
Can someone tell me what is wrong here?
When it gets to line 15 it simply exits with no error and no update...
<SPAN class="keyword token">if</SPAN> count<SPAN class="operator token"><></SPAN><SPAN class="string token">"0"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="comment token"># only feature classes with features</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"BDV"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cur <SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cur<SPAN class="punctuation token">:</SPAN>
row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="operator token">=</SPAN>date
cur<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">del</SPAN> row
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"BIN"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor_Name<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> prow <SPAN class="keyword token">in</SPAN> cursor_Name<SPAN class="punctuation token">:</SPAN>
prow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="operator token">=</SPAN>NN_code
cursor_Name<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>prow<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">del</SPAN> prow<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
