I have a value in a field string example "Test /n Test1...".If I publish a mapserver and I do a request rest query with response type json: it returns "Test //n Test1..." but from json.org for newline in string I use /n. In rest esri uses QueryData because I have tried with this method and I have same response but if I use IRecordset I have no problem.
ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Desktop);
IRecordSet pNewRs = new RecordSet();
IRecordSetInit prsInit = pNewRs as IRecordSetInit;
IFields pFields = new Fields();
IFieldsEdit pFieldsEdit = pFields as IFieldsEdit;
pFieldsEdit.FieldCount_2 = 2;
IField pField = new Field();
IFieldEdit pFieldEdit = pField as IFieldEdit;
pFieldEdit.Name_2 = "Type";
pFieldEdit.Type_2 = esriFieldType.esriFieldTypeString;
pFieldEdit.Length_2 = 50;
pFieldsEdit.set_Field(0,pField);
pFieldEdit.Name_2 = "Area";
pFieldEdit.Type_2 = esriFieldType.esriFieldTypeDouble;
pFieldsEdit.set_Field(1,pField);
prsInit.CreateTable(pFields);
ICursor pIC = prsInit.Insert();
IRowBuffer pRowBuf = prsInit.CreateRowBuffer();
pRowBuf.set_Value(0, "Test /n Test1");
pRowBuf.set_Value(1, 10.2);
pIC.InsertRow(pRowBuf);
byte[] fs = Conversion.ToJson(pNewRs);
using (System.IO.FileStream f = new System.IO.FileStream(@c:\test.txt, System.IO.FileMode.Create))
f.Write(fs, 0, fs.Length);
f.Flush();
f.Close();
I have "Test \n Test1" in test.txt:
{"displayFieldName":"","fieldAliases":{"Type":"Type","Area":"Area"},"fields":[{"name":"Type","type":"esriFieldTypeString","alias":"Type","length":50},{"name":"Area","type":"esriFieldTypeDouble","alias":"Area"}],"features":[{"attributes":{"Type":"Test \n Test1","Area":10.2}}]}
