I'm having problems with Push Text to an External TCP Socket after having upgraded to 10.3.
For some reason I am getting the following error when trying to create the output
| com.esri.ges.transport.tcp.TcpOutboundTransport | Exiting TCP Transport due to unforeseen error. java.net.ConnectException: Connection refused: connect at sun.nio.ch.Net.connect0(Native Method)[:1.7.0_65] at sun.nio.ch.Net.connect(Net.java:465)[:1.7.0_65] at sun.nio.ch.Net.connect(Net.java:457)[:1.7.0_65] at sun.nio.ch.SocketChannelImpl.connect(SocketChannelImpl.java:670)[:1.7.0_65] at com.esri.ges.transport.tcp.TcpOutboundTransport.attemptClientConnection(TcpOutboundTransport.java:127)[265:com.esri.ges.framework.transport.tcp-transport:10.3.0] at com.esri.ges.transport.tcp.TcpOutboundTransport.applyProperties(TcpOutboundTransport.java:406)[265:com.esri.ges.framework.transport.tcp-transport:10.3.0] at com.esri.ges.transport.tcp.TcpOutboundTransport.run(TcpOutboundTransport.java:351)[265:com.esri.ges.framework.transport.tcp-transport:10.3.0] at java.lang.Thread.run(Thread.java:745)[:1.7.0_65] | Feb 13, 2015, 11:22:34 AM | ERROR |
Trying to import Module4_QuickStart.xml from the tutorial data gives the same error.
Everything was working fine at 10.2.2
Anybody knows what's going on here?
