I'm using the arcpy lib in arcgis 10.1 and to work on a script. When i use the arcpy.CalculateField_management i'm getting an error . Could someone help me identify whats wrong with the expression below. I'm using VB because when i use the python calculator, python crashes at the end of the calculation so VB is the only option i have. Notice that this expression work good when using python but like i mentioned, when the python option is used. python crashes at the end of the script. arcpy.CalculateField_management("TAZ_un_Buffer_Dissolve.shp", "totalArea","[shape.area]", "VB", "")Traceback (most recent call last): File "D:\CubeAlbuquerque\AlbuquerqueNewTAZ\02_Applications\02_Transit_walk_Acc ess\ptaccess_SM.py", line 55, in <module> arcpy.CalculateField_management("TAZ_un_Buffer_Dissolve.shp", "totalArea","[ shape.area]", "VB", "") File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\management.py", li ne 3128, in CalculateField raise e arcgisscripting.ExecuteError: ERROR 999999: Error executing function. Failed to execute (CalculateField).
