Hi,I have downloaded and installed the ArcGIS API for iOS (Update 1) and using iPhone SDK 4.0.I was unable to build and run the "MyFirstMapApp" code.Subsequently, I tried to run the default sample codes (MapView) included in the SDK, but it failed to run too. In both instances, the following error was display.is there a problem with the org.brautaset.JSON framework?Can anyone kindly advise?Thanks.2010-07-26 15:14:30.529 MapViewDemo[2511:207] -JSONValue failed. Error trace is: (
"Error Domain=org.brautaset.JSON.ErrorDomain Code=3 \"Unrecognised leading character\" UserInfo=0x5c130e0 {NSLocalizedDescription=Unrecognised leading character}"
2010-07-26 15:14:31.411 MapViewDemo[2511:207] -JSONValue failed. Error trace is: (
"Error Domain=org.brautaset.JSON.ErrorDomain Code=3 \"Unrecognised leading character\" UserInfo=0xd8013f0 {NSLocalizedDescription=Unrecognised leading character}"
2010-07-26 15:14:31.413 MapViewDemo[2511:207] *** Terminating app due to uncaught exception 'NSRangeException', reason: '*** -[NSMutableArray objectAtIndex:]: index 0 beyond bounds for empty array'
*** Call stack at first throw:
0 CoreFoundation 0x02643919 __exceptionPreprocess + 185
1 libobjc.A.dylib 0x027915de objc_exception_throw + 47
2 CoreFoundation 0x02639465 -[__NSArrayM objectAtIndex:] + 261
3 MapViewDemo 0x00046b71 -[AGSMapView layerDidLoadHandler:] + 313
4 Foundation 0x00116c1d _nsnote_callback + 145
5 CoreFoundation 0x0261bcf9 __CFXNotificationPost_old + 745
6 CoreFoundation 0x0259b11a _CFXNotificationPostNotification + 186
7 Foundation 0x0010c7c2 -[NSNotificationCenter postNotificationName:object:userInfo:] + 134
8 Foundation 0x00118b05 -[NSNotificationCenter postNotificationName:object:] + 56
9 MapViewDemo 0x000517a9 -[AGSTiledLayerView agsLayerDidLoad:] + 72
10 CoreFoundation 0x025b442d __invoking___ + 29
11 CoreFoundation 0x025b4301 -[NSInvocation invoke] + 145
12 Foundation 0x0012be9a __NSThreadPerformPerform + 251
13 CoreFoundation 0x02624d7f __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 15
14 CoreFoundation 0x025832cb __CFRunLoopDoSources0 + 571
15 CoreFoundation 0x025827c6 __CFRunLoopRun + 470
16 CoreFoundation 0x02582280 CFRunLoopRunSpecific + 208
17 CoreFoundation 0x025821a1 CFRunLoopRunInMode + 97
18 GraphicsServices 0x02ea82c8 GSEventRunModal + 217
19 GraphicsServices 0x02ea838d GSEventRun + 115
20 UIKit 0x003bab58 UIApplicationMain + 1160
21 MapViewDemo 0x000024e4 main + 102
22 MapViewDemo 0x00002475 start + 53
23 ??? 0x00000001 0x0 + 1
terminate called after throwing an instance of 'NSException'
