I wish to create a function to change basemap.
To test the concept, I created a map and added a ArcGISTiledMapServiceLayer
var tiled = new ArcGISTiledMapServiceLayer('http://services.arcgisonline.com/ArcGIS/rest/services/NatGeo_World_Map/MapServer'); Next, I will remove the layer and add a ArcGISImageServiceLayer to stimulate a change basemap action
var image = new ArcGISImageServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Toronto/ImageServer", { imageServiceParameters: params, opacity: 0.75 }); What I realised is after these [adding tiled, removing tiled, adding image] actions, no layers will be rendered
I tested other scenarios and these are the results:
1) If I do not remove the tiled layer, both layers get rendered
2) If I add only image layer, image layer get rendered
3) If I add only tiled layer, tiled layer get rendered
Do you guys have any advice as to why I cannot perform a remove layer action?
To make this question understandable, I created a sample fiddle that can illustrate my case. Simply remove the removeLayer comment in the fiddle and run it. You will notice as mentioned, nothing will be rendered.
https://jsfiddle.net/82qjh0wg/
