Hi, i got a problem with my python toolbox.
First, i have a toolbar (test_addin) with 3 buttons:
Button1 will activate Button2 and deactivate himself. Same thing for Button2.
"Go" will start a tool in a python toolbox.
This tool have a parameter object with a defaut value set to "1" or "2" depending on which button is activated.
The problem is: when i execute the tool, it work one time, but when i try to activate the other button, and then rerun the tool,
the defaut value for the parameter is not refreshing. I have to refresh the python toolbox manually to make it work.
Is there a way to make this work automatically?
Tank you!
Charles
Toolbar:
import arcpy
import pythonaddins
class ButtonClass1(object):
"""Implementation for test_addin.button1 (Button)"""
def __init__(self):
self.enabled = True
self.checked = False
def onClick(self):
button1.enabled = False
button2.enabled = True
gobutton.enabled = True
class ButtonClass2(object):
"""Implementation for test_addin.button2 (Button)"""
def __init__(self):
self.enabled = False
def onClick(self):
button2.enabled = False
button1.enabled = True
class GoClass3(object):
"""Implementation for test_addin.gobutton (Button)"""
def __init__(self):
def onClick(self):
tbx = r"V:\mes documents\ArcGIS\AddIns\test\Install\Toolbox.pyt"
tool = "Tool"
arcpy.RefreshCatalog(tbx)
pythonaddins.GPToolDialog(tbx, tool)
python toolbox:
import arcpy
import test_addin
class Toolbox(object):
def __init__(self):
"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""
self.label = "Toolbox"
self.alias = ""
# List of tool classes associated with this toolbox
self.tools = [Tool]
class Tool(object):
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "Tool"
self.description = ""
self.canRunInBackground = False
def getParameterInfo(self):
"""Define parameter definitions"""
reload(test_addin)
# First parameter
param0 = arcpy.Parameter(
displayName="Active button",
name="button",
datatype="String",
parameterType="Required",
direction="Input")
if test_addin.button1.enabled == True:
param0.value = "1"
if test_addin.button2.enabled == True:
param0.value = "2"
params = [param0]
return params
def isLicensed(self):
"""Set whether tool is licensed to execute."""
return True
def updateParameters(self, parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
return
def updateMessages(self, parameters):
"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""
return
def execute(self, parameters, messages):
"""The source code of the tool."""
arcpy.AddWarning(parameters[0].valueAsText)
return
