Hello, I watched and worked along the GTFS tutorials using similar process with different data (NYC) and it worked pretty well. I used ArcMap. Now I am trying to do it in ArcGIS Pro and it's just not the same. I am using the same network dataset created with ArcMap. Should I start from scratch? For example, I have problems with the units, it seems something is not quite there with the cutoffs, when I do Service Area. The Network Dataset Properties window looks only somewhat familiar. Any suggestions regarding the transition to ArcGIS Pro?
Thank you,
Horia.
