Hello
I try to edit attribute table for 20 shapefiles that spread in big a folder and are divided to a lot of sub folders. All shapefiles are called "migrashim" and the name of the filed that i want to change is "structuretype". I try this code:
when i run this code:
import arcpy,os,sys
from arcgisscripting import da
pattern = 'migrashim.shp'
folder = r"C:\Project\layers" ## root folder
field = 'YEUD' ## your field where calculation to be applied
files_process = []
for root,dirs,files in os.walk(r"C:\Project\layers"):
for filenames in files:
if filenames == pattern:
files_process.append(os.path.join(root, filenames))
for i in files_process:
curU = arcpy.UpdateCursor(i)
for row in curU:
row.setValue(field, 500)##Any expression you want
curU.updateRow(row)
del curU
i get an error:
File "C:\Users\yaron.KAYAMOT\Desktop\ar.py", line 1, in <module>
import arcpy,os,sys
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\__init__.py", line 24, in <module>
from arcpy.toolbox import *
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\toolbox.py", line 15, in <module>
from .ddd import ASCII3DToFeatureClass as ASCII3DToFeatureClass_3d
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\ddd.py", line 23, in <module>
from arcpy.arcobjects.arcobjectconversion import convertArcObjectToPythonObject
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\arcobjects\__init__.py", line 15, in <module>
from _base import *
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\arcobjects\_base.py", line 16, in <module>
from .arcobjectconversion import convertArcObjectToPythonObject
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\arcobjects\arcobjectconversion.py", line 2, in <module>
import arcpy.mapping
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\mapping.py", line 15, in <module>
from _mapping import MapDocument, Layer, TableView, constants
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\_mapping.py", line 15, in <module>
from arcpy.arcobjects import mixins
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\arcobjects\mixins.py", line 16, in <module>
curU = arcpy.da.UpdateCursor(i,field)
AttributeError: 'module' object has no attribute 'da'
i need help !!
