I have installed a local copy of the javascript API following the instructions here How To: Install the JavaScript API for use with ArcGIS for Server
When I test a service in the Javascript preview from the rest endpoint, the service does not load properly. It just displays a blank page.
In the developer console I get the following errors:
Two of the paths that it is looking for (arcgis_js_api/library/3.13/3.13/esri/views/MapView.js and ....esri/widgets/Home.js) do not exist in the wwwroot folder where I have installed the api. I am required to use the 3.13 version because of the application that we are using. Is this some problem with the Javascript viewer at the rest end point requiring these files that do not exist in the 3.13 version? The server is 10.7, and it is federated with Portal on another machine.
