Hi all, I am new to Python and I am currently working on a project where I am attempting to use the update cursor to use a numeric value in a field, and populate a secondary field with text values based off of those numeric values. This code will run successfully, but it will not update the field as desired. My e.message is giving me an __exit__ message. Here is my code:
# Import system modules
import arcpy
from arcpy import env
# Set environment settings
env.workspace = "F:\Geog390\Lab 3\Lab3.gdb"
env.overwriteOutput = True
fc = 'TPSJ'
fields = ('Join_Count', 'Validate')
#'TPSJ' is my feature class, 'Join_Count' is my first field, and 'Validate' is the field I am trying to populate
try:
with arcpy.UpdateCursor(fc,fields) as cursor:
for row in cursor:
if row.getValue[JOIN_COUNT] == 1:
row.setValue[VALIDATE] = "Validated"
else:
row.setValue[VALIDATE] = "Not Validated"
cursor.updateRow(row)
except Exception, e:
print e.message
any help would be greatly appreciated, thanks!
