I'm using the sample code [PopupInWebMapForViewing] provided by ArcGIS SDK.I placed my arcgis.com webmap link into the sample code and was able to view my map I created on arcgis.com as well as the popups I configured.My question:How do I add a button to my map view using the webmap mapview?Do I use XML or do I code the button in java?The sample code for viewing the map: /** Called when the activity is first created. */
public void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
// Load a webmap.
map = new MapView(this, "http://www.arcgis.com/home/item.html?id=ec84873154cf43069c407", "", "");
setContentView(map);
I've used buttons before, but I called on my ArcGISDynamic map services in a slightly different way.This is how I coded my button previously:/** Called when the activity is first created. */
setContentView(R.layout.mapscreen);
// Retrieve the map and initial extent from XML layout
map = (MapView) findViewById (R.id.map);
// This adds ESRI's titled map service layer "World Street Map" to the MapView, as well as DHEC's
// dynamics map service "MPOS"
map.addLayer(new ArcGISTiledMapServiceLayer("" +
"http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"));
map.addLayer(new ArcGISDynamicMapServiceLayer("" +
"http://TEST/ArcGIS/rest/services/Mobile/TRSS/MapServer"));
//Setting up the button reference.
ZoomToMyLocation = (Button) findViewById (R.id.button1);
