I have a polygon layer and a table that shows records relating to the different polygons. I have both hosted on ArcGIS online and want to show a chloropleth map (online) showing the number of points that intersect with the polygons. I also want the data to be easy to edit as I will be continually adding to the table, so the fewer steps I have to redo over and over again to update the chloropleth map would be ideal.
I've searched forums and tried different tools on ArcPro but nothing is quite working, most of them require an output and I'm not having much luck getting what I want. I've also tried joins and creating a "count" field and different forms of "intersect" type tools, but I can't find the right one.
