So I was trying to create a regular dijit/form/MultiSelect but can't seem to get it to populate any values using JS. As I was looking for examples in other wigets I notice the query widget has a nice multi select drop down widget. This would fit my needs much better. Anyone have any knowledge on how to create this?
If not I will keep trying to get my regular multiselect working.
<SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> option<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> optionsArray <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">let</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">switch</SPAN> <SPAN class="punctuation token">(</SPAN>selectField<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">"capCat"</SPAN><SPAN class="punctuation token">:</SPAN>
option <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>value<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>CAT_No<SPAN class="punctuation token">,</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>CAT_Begin_Dt<SPAN class="punctuation token">,</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>CAT_End_Dt<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> label<SPAN class="punctuation token">:</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>CAT_Full_Name<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">;</SPAN>
optionsArray<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>option<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="string token">"capPeril"</SPAN><SPAN class="punctuation token">:</SPAN>
option <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>value<SPAN class="punctuation token">:</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>COVERAGE<SPAN class="punctuation token">,</SPAN> label<SPAN class="punctuation token">:</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>COVERAGE<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Use this if regular select</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>selectField <SPAN class="operator token">==</SPAN> <SPAN class="string token">"capCat"</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Add a defualt option first</SPAN>
<SPAN class="keyword token">let</SPAN> option1 <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"-"</SPAN><SPAN class="punctuation token">,</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Select a "</SPAN> <SPAN class="operator token">+</SPAN> title<SPAN class="punctuation token">,</SPAN> selected<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
select<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addOption</SPAN><SPAN class="punctuation token">(</SPAN>option1<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Then add the rest of the options</SPAN>
select<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addOption</SPAN><SPAN class="punctuation token">(</SPAN>optionsArray<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//use this if multiselect </SPAN>
<SPAN class="comment token">//Attempt to load using store/Memory</SPAN>
select<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"store"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Memory</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>data<SPAN class="punctuation token">:</SPAN> optionsArray<SPAN class="punctuation token">,</SPAN> idProperty<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"value"</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
select<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"labelAttr"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"label"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>select<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
