In my Javascript API Web application I'm using the infoWindow to query a parcel layer and display display information in a popup when I click the parcel. I've set this functionality to turn on and off depending on if the parcel is visible, and I control the visibility of my different layers with check boxes in a legend. Every time the parcel layer is checked on of off it calls the clickConnect function with a value of true or false. Depending on this, click connect will call the executeIdentifyTask function, which query's the parcel layer, when clicked, and displays the info in a popup. This works great unless I try to use the esri.dijit.Measurement tool while the parcel layer is turned on. In which case i still get a pop up every time I click, which gets in the way of me measuring parcels. Is there a way that I could turn the popup/query functionality off while I'm using the measure tool and the parcel layer is turned on? I'm a bit of a beginner at using javascript/dojo so I'm not sure how to do this. Any help would be greatly appreciated! I hope I was clear in my explanation, if not let me know!Javascript from my map app relevant to the question: var app = {}; app.map = null; var legendLayers = []; var clickHandler; function init() { //add popup var popup = new esri.dijit.Popup({ fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25])) }, dojo.create("div")); //add geometry service esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://server/rest/services/Utilities/Geometry/GeometryServer"); //initalize map app.map = new esri.Map("map", { basemap : "streets", center : [-111.924531, 40.611871], zoom : 13, infoWindow: popup }); //add parcel layer var parcels = new esri.layers.ArcGISDynamicMapServiceLayer("http://server/arcgis/rest/services/Parcels_UT/MapServer", { id : 'parcels', visible : false }); legendLayers.push({ layer : parcels, title : 'Parcels' }); //add parcel query data var content = "<b>Address</b>: ${ADDR}" + "<br /><b>Owner Name</b>: ${OWNER}" + "<br /><b>Parcel ID</b>: ${APN}" + "<br /><b>City</b>: ${CITY}" + "<br /><b>Acres</b>: ${TOTAL_ACRE}" + " <br /><a href='${COUNTY_LIN}'>County Assessor Site</a>" var popUpTemplate = new esri.InfoTemplate("Parcel", content); //add paercel layer as feature layer var featureLayer = new esri.layers.FeatureLayer("http://server/arcgis/rest/services/Parcels_UT/MapServer/0",{ mode: esri.layers.FeatureLayer.MODE_SELECTION, outFields: ["*"], infoTemplate:popUpTemplate }); //create legend dojo.connect(app.map, 'onLayersAddResult', function(results) { var legend = new esri.dijit.Legend({ map : app.map, layerInfos : legendLayers }, "legendDiv"); legend.startup(); }); app.map.addLayers([parcels]); dojo.connect(app.map, 'onLayersAddResult', function(results) { //add legend check boxes dojo.forEach(legendLayers, function(layer) { var layerName = layer.title; var checkBox = new dijit.form.CheckBox({ name : "checkBox" + layer.layer.id, value : layer.layer.id, checked : layer.layer.visible, onChange : function(evt) { var clayer = app.map.getLayer(this.value); clayer.setVisibility(!clayer.visible); this.checked = clayer.visible; //toggle the feature layer with the parcel layer if (this.value ==="parcels" && this.checked === true){ clickConnect(true); console.log("parcels"); } else if (this.value ==="parcels"){ clickConnect(false); console.log("noParcels"); } } }); //add the check box and label to the table of contnents dojo.place(checkBox.domNode, dojo.byId("toggle"), "after"); var checkLabel = dojo.create('label', { 'for' : checkBox.name, innerHTML : layerName }, checkBox.domNode, "after"); dojo.place("<br />", checkLabel, "after"); }); }); dojo.connect(app.map, 'onLoad', function(map) { initToolbar(app.map); }); function executeIdentifyTask(evt) { var query = new esri.tasks.Query(); query.geometry = pointToExtent(app.map,evt.mapPoint,10); var deferred = featureLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW); app.map.infoWindow.setFeatures([deferred]); app.map.infoWindow.show(evt.mapPoint); } function clickConnect(connect){ if(connect){ //perform the identify task on click clickHandler = dojo.connect(app.map, "onClick", executeIdentifyTask); }else{ //disconnect the click handler dojo.disconnect(clickHandler); clickHandler = null; } } } function initToolbar(mymap) { //define a new line symbol and point symbol to use for measure tools var pms = new esri.symbol.PictureMarkerSymbol("images/flag.png", 24, 24); pms.setOffset(9, 11); var sls = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DOT, new dojo.Color([255, 0, 0, .55]), 4); var measurement = new esri.dijit.Measurement({ map : mymap, lineSymbol : sls, pointSymbol : pms }, dojo.byId('measurementDiv')); measurement.startup(); measurement.setTool("area", false); } function pointToExtent(map, point, toleranceInPixel) { var pixelWidth = map.extent.getWidth() / map.width; var toleraceInMapCoords = toleranceInPixel * pixelWidth; return new esri.geometry.Extent( point.x - toleraceInMapCoords, point.y - toleraceInMapCoords, point.x + toleraceInMapCoords, point.y + toleraceInMapCoords, map.spatialReference ); } dojo.ready(init);
