I am trying to convert a MySQL table to a personal geodatabase table using TableToGeodatabase and MySQLdb (to connect to the db). I'm able to successfully connect to the database and query it, I am just not able to correctly select the table to be converted. Although I am using an .mdb instead of a .gdb, this does not throw an error. The only error I receive is "ERROR 000735: Input Table: Value is required"# Import system modules
import arcpy
from arcpy import env
import MySQLdb
import sys
# open a database connection
try:
connection = MySQLdb.connect(host="host.org", user="abcde", passwd="12345", db="waterdb")
if connection.open:
print "open"
# Set environment settings
# I believe this should reference the MySQL database but I don't know how
env.workspace = ""
# the table I want to convert
table = arcpy.ListTables(["vwComboFlows"])
# Set local variables
outLocation = "C:/output/output.mdb"
try:
# Execute TableToGeodatabase
print "Importing tables to mdb: " + outLocation
arcpy.TableToGeodatabase_conversion(table, outLocation)
except:
print arcpy.GetMessages()
