HELP!I am working on a JavaScript web page that does two things:1) Query a rest service for the attribute information from a single record and then presents it in a table.2) Builds a map and zooms to the results from the query. I used the "Query State Info without Map" to start with and to accomplish the first task. I added a map (basemap plus a couple of additional layers for display). However, I am unable to extract the geometry from the query results as a point to use when creating the map.The rest service I'm using for the query is not exposed to the internet so I have reworked and simplified my code (using just the sample code and internet services) to the basics so I can learn what I'm doing and apply it to my actual page:<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css"> <title>Query State Info with Map</title> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script> <script> dojo.require("esri.tasks.query"); dojo.require("esri.map"); var queryTask, query, centerPoint, stateName; var stateName = "Colorado" /* stateName for QueryTask */ function init() { /* Setup query */ queryTask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"); query = new esri.tasks.Query(); query.returnGeometry = true; query.outSpatialReference = new esri.SpatialReference({wkid : 102100}); query.outFields = ["STATE_NAME","SQMI","SUB_REGION"]; query.text = stateName; queryTask.execute(query, showResults); } function showResults(results) { var s = ""; for (var i=0, il=results.features.length; i<il; i++) { var featureAttributes = results.features.attributes; for (att in featureAttributes) { s = s + "<b>" + att + ":</b> " + featureAttributes[att] + "<br />"; } } dojo.byId("info").innerHTML = s; /* Extract Geometry From Query */ centerPoint = new esri.geometry.Point(getPoint(results)); //Does NOT work- Actual use will be a point layer // centerPoint = [-122.45, 37.75] //fake point for testing /* Build Map */ map = new esri.Map("map",{ basemap: "topo", center:centerPoint, zoom:13 }); map.addLayer(new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer", { "opacity":0.2, spatialReference: map.spatialReference })); /* Add ESRI Census Map */ } dojo.ready(init); </script> </head> <body class="claro"> <div id="info" style="padding:5px; margin:5px; background-color:#eee;"></div> <div id="map"></div> </body> </html>Can someone please help me understand how to extract the geometry of the results to a variable that can then be used to create a center-point in a map?Thank you,
